AL- help, How do you setup app rate module with flow meter input
tedbear
Posted 4/3/2025 09:17 (#11173038 - in reply to #11172683)
Subject: RE: AL- help, How do you setup app rate module with flow meter input
I setup an InCommand 1200 in my basement lab and went through the process of creating a configuration such as you would use. I personally use an Application Rate module with a Raven RFM 15 flowmeter for monitoring starter fertilizer on our corn planter. I also setup another Application Rate module for my Nephew's hog manure rig. The hog manure rig is a Nuhn with a Yamatake mag meter. The Yamatake produces a digital output similar to what a Hall effect flow meter would produce. They are both working with InCommand 1200's.
I took several pictures but will just post those that seem to be less than obvious. Again I feel your shaft sensor will be a problem but you may as well try it.
The term flow meter is used for both an actual flow meter for liquids or a shaft sensor for other products.
Some of the screens are obvious others seem to apply to flow meters as any device that measures flow in some respect with digital pulses.
Edited by tedbear 4/3/2025 10:07
(IMG_2785 (full).JPG)
(IMG_2786 (full).JPG)
(IMG_2787 (full).JPG)
(IMG_2788 (full).JPG)
(IMG_2789 (full).JPG)
(IMG_2790 (full).JPG)
(IMG_2791 (full).JPG)
(IMG_2793 (full).JPG)
(IMG_2800 (full).JPG)
(IMG_2801 (full).JPG)
(IMG_2802 (full).JPG)
(IMG_2803 (full).JPG)
(IMG_2804 (full).JPG)
(IMG_2805 (full).JPG)
(IMG_2807 (full).JPG)
(IMG_2808 (full).JPG)
(IMG_2809 (full).JPG)
(IMG_2810 (full).JPG)
(IMG_2811 (full).JPG)
Attachments IMG_2785 (full).JPG (85KB - 12 downloads)
Attachments IMG_2786 (full).JPG (61KB - 12 downloads)
Attachments IMG_2787 (full).JPG (66KB - 10 downloads)
Attachments IMG_2788 (full).JPG (66KB - 12 downloads)
Attachments IMG_2789 (full).JPG (66KB - 12 downloads)
Attachments IMG_2790 (full).JPG (64KB - 12 downloads)
Attachments IMG_2791 (full).JPG (59KB - 12 downloads)
Attachments IMG_2793 (full).JPG (61KB - 12 downloads)
Attachments IMG_2800 (full).JPG (69KB - 11 downloads)
Attachments IMG_2801 (full).JPG (67KB - 12 downloads)
Attachments IMG_2802 (full).JPG (64KB - 12 downloads)
Attachments IMG_2803 (full).JPG (69KB - 11 downloads)
Attachments IMG_2804 (full).JPG (60KB - 12 downloads)
Attachments IMG_2805 (full).JPG (66KB - 12 downloads)
Attachments IMG_2807 (full).JPG (86KB - 11 downloads)
Attachments IMG_2808 (full).JPG (60KB - 12 downloads)
Attachments IMG_2809 (full).JPG (57KB - 12 downloads)
Attachments IMG_2810 (full).JPG (59KB - 12 downloads)
Attachments IMG_2811 (full).JPG (70KB - 11 downloads)
